owen021173
hi,i hope this is the correct place to post ???
after the info provided by this forum i have just purchased a panny 50px60 which i am more than happy with.its the connections im having a problem with!
i have- panny 50, xbox 360, panasonic home theatre sc-ht500, sky + and a toshiba dvr 16 dvd/vcr combo.
i had everything working fine until i added the toshiba dvd recorder which i changed all the connections around so i got a vga lead for the xbox 360 instead of the component lead which is supplied.the toshiba is now through component leads as i thought this would give me better dvd quality due to the progressive scan on the tosh where as the panny dvd doesnt do progressive.anyway i can only get the dvd showing on av1 which is my sky+ input and have to turn the sky box off to see the picture.on the av it list the yellow button for component and pc with the xbox now on pc with vga i thought the dvd would show on component???
another prob is with the xbox 360. i would like some form of surround from this but my home theatre doesnt have the correct inputs on the back.with the vga cable there was a connecter with a red and white connection and something like a headphone jack on the other end.
can this be fabricated to use an audio lead to get the surround sound???
thank you for taking the time to read this rather long first post!
any help or recommendations regarding setting up all this with the correct cables etc will be more than welcomed!!!!
thank you
thank you
