Panasonic 50PX60 Box
jmela
I am considering getting the Panasonic 50PX60 from Richer Sounds, but seeing as they dont deliver I'll have to collect. Does anyone know the dimensions of the box so I can try and work out if theres any way it will fit in my car?
Thanks,
Jan
136cm length 40cm width 96cm height hope you have a large car
thats just the tv
Tonyrec
I picked mine up last week and it only just fitted (height wise) into the back of my Disco3.
The box was just rubbing on the top of the roof. Another quarter of an inch and it would not have gone in.
Ive just measured the opening on the car which is 95cms high so the box is just under this......only just.
Ive also just measured the height of my telly and its only 82cms high.
Podcast: Best Home Cinema Sources and B&W 805 D4 Speaker Review and more...
