F
fuzzb
I have written this guide as no one else seems to have done so, and it took me hours to figure this out so I thought I would share the info
You will need the files in this archive: http://www.myfootballonline.com/Plasma/50PV500Mapping.zip
1) Update monitor driver - select custom 50PV500 driver (50PV500Driver.inf)
2) Set up PowerStrip, paste in settings below:
PowerStrip timing parameters:
1368x768=1368,192,96,248,768,10,6,23,91125,2054
Generic timing details for 1368x768:
HFP=192 HSW=96 HBP=248 kHz=48 VFP=10 VSW=6 VBP=23 Hz=59
Linux modeline parameters:
"1368x768" 91.125 1368 1560 1656 1904 768 778 784 807 -hsync -vsync
3) Use the Nokia Monitor Test application (http://www.majorgeeks.com/download960.html) to adjust your TV H & V positioning until it is perfectly centered. You may find that you are missing 2 vertical lines. This is completely normal as the TV resolution is 1366 and the resolution we are configuring is 1368.
4) Set up your desktop background as '2 Stripe Background.bmp', then set mode to 'Tile'. Your desktop should now be pinstripe black/white.
5) At this point you may notice some interference on the pinstripe pattern, like wavy lines etc. This is normal and means you need to adjust your clock and/or phase on the 50PV500's setup menu. As you adjust either of these you will notice the pinstripe picture improve or go worse. You need to configure it so that the pinstripe image is solid black & white with no interference.
Voila! Your plasma should now be mapped 1:1 with a crystal clear picture.
