Panasonic 50"
Discussion in 'Plasma TVs' started by rscott4563, Nov 26, 2003.
  1. rscott4563
    rscott4563
    Jan 21, 2003
    1,051
    38
    Cumbria
    Is there any difference between the Panasonic 50PHW and the Panasonic 50PHD?? Ivojo has the PHW @ only £4,816.33 inc. VAT which seems a very good price! But the PHD is £6,063.00 inc. VAT, I know with the 42" models the PHW is the SD and the PHD is the HD but with the 50" models are both HD with a 1366 x 768 resolution? So why the £1246.67 difference, also I thought the commercial models were normally less expensive than the consumer versions...
  2. rscott4563
    rscott4563
    Jan 21, 2003
    1,051
    38
    Cumbria
    Oh hang on just had another look and have now noted that the PHD is a 5 series and the PWD is the newer 6 series, so I suppose that answers my question regarding the price difference, ie the newer models are almost always cheaper than the equivalent previous model....
    So does anyone know if this is the best price for the 50PWD, can't wait till the Pio 504HDE is out so I can do a proper comparison. :D
