Panasonic 5/6 Owners
Discussion in 'Plasma TVs' started by Paden, Jul 29, 2003.
  1. Paden
    Paden
    Jul 27, 2000
    554
    +13
    Is it possible to do anything about the green "on" LED on the front of the panel, i.e. switch it off via software?
    It's a real pain & it's sooooooooooo bright!
    My Sony TV had it right, a red LED for stanby which went out when I switched the set on leaving the surrounding bezel unilluminated.
    Cheers, Paul
  2. nathan_silly
    nathan_silly
    Blu-tack!
    My Tosh RP has two LED's, covered with a couple of blobs.
  3. bluebear
    bluebear
    Place a small square of black insulation tape over the LED.
    I don't cover up my LED as I want to know if I have left the screen switched ON before I go to bed !! (Screen burn, ouch...)
    Regards,
    Bluebear.
    :cool:
  4. CarlB
    CarlB
    Jan 8, 2001
    1,110
    Godmanchester, Cambs
    +96
    Surely the big shiny 42" picture glowing at you gives you some indication of whether the screen has been left on... ;)
    On my set (Model 4) if there is no signal then the screen is entirely black, therefore there would be no chance of screen burn in this case.
  5. bluebear
    bluebear
    CarlB,
    If you noticed I have got a Model 4 !
    The screen does go blank after a few seconds after the "NO Signal" is displayed.
    So if I turn off the DVD or Freeview box, and forget to turn off the screen then the screen will be powered all night, you can see a small white glow, the screen is still powered and will still degrade over time, it does not go into standby.
    Bluebear.
  6. pizzacheaze
    pizzacheaze
    i agree, the green led is a pain
