panasonic 42pw6 from ilgroup
Discussion in 'Panasonic TVs Forum' started by frank.leggett, Dec 3, 2003.
  1. frank.leggett
    frank.leggett
    Nov 29, 2003
    62
    Sussex
    After visiting my local Panasonic shop I have taken the plunge and bought a 42 pwd6 from ilgroup.co.uk. It comes as standard with a BNC component, composite and SVHS board. The salesman said that it was in fact to boards a component board with a 15 pin d input and a composite/SVHS board leaving one spare which I have ordered a scart socket for (SKY). The salesman said the component input was a RGBHV input with only the RGB needed for a component input. In short I know other people have bought the board from ilgroup so I was wondering do I need to get a VGA to component lead or by a proper component board with BNC or phono inputs.
  2. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
    The panel comes with an inbuilt VGA connection using a DB15 plug, so you can use an RCA => DB15 cable if you want to use this connection - and yes it will accept component via this connection (or a PC connection)
    The free board (TY-42TM6Y) is a two slot board which has BNC component connectors + SVideo + Composite
    Have a look at the brochure here:
    http://www.nexnix.co.uk/pds/docs/Panasonic Plasma 6.pdf
    JJ
    P.S. Screen and terminal manuals here: http://www.avforums.com/forums/showthread.php?s=&threadid=104499
  3. frank.leggett
    frank.leggett
    Nov 29, 2003
    62
    Sussex
    Thanks alot. Now I Know which cables to get.
