Quantcast
Panasonic 42PW6 all set up :) - Advice!
GarethH
Got my Panasonic 42PW6B yesterday and tonight have just switched it on for the first time. Still waiting on the component board though as AV-Sales is awaiting stock. I currently have the DVD player connected up through Scart...picture aint as great as i expected...I guess thats normal for scart though right. I've not played with any settings at all yet!
Could anyone give me some advice on burn in and what settings I should use in general..giving two options for pre 200 hour and post 200 hour? I've search the forums btw, i find nothing! If your gonna tell people to search, at least tell them what they should search under ;)
All in all, it looks very cool...just can't wait till my component board turns up and I can run it in progressive!
D J Fryer
I am a new PW6 owner and I have taken the contrast setting down to -10, brightness at about -4 - I imagine the others are personal taste or use the THX optimode test on some discs. Because I use the VGA in for Sky+ there is no change of the colour settings whereas you can adjust these on the component input. I can't say I remember what mine are though.........?
MattTheBeanster
I used (and still do) the cinema setting with the brightness dialled down a little bit. I always keep the peak limit on unless watching dvd's.
Burn doesn't seem to be a problem for the panasonics, i played a ps2 game with constant huds for up to 3 hours before the 100 hour breakin and have since played for up to 7 hours straight. Not a glimmer of a problem.
samhain
Those settings are remarkably similar to mine. Using VGA box to connect Sky to Plasma. Picture looks fab. Not used DVD via my component board yet so can't comment.
