panasonic 42pv500-denon2910 a good pairing?
Discussion in 'General TV Discussions Forum' started by crank, Jul 28, 2005.
Tags:
  1. crank
    crank
    hi all, im am thinking of purchasing a denon 2910 to broadcast dvds on my new panasonic 42pv500 plasma via hdmi cable. does anyone know if this would be a good match , or have any views please advise,,,,
    also i am a bit miffed about hdmi is this capable of transmitting a progressive signal or is that only component....................cheers :lease:
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    You may get more response by asking about each component in their dedicated forums, if both get good reviews then putting them together should provide satisfaction:)
    The 2910 has upscaling technology so matched with a HD Ready panel the need for progressive via component is a thing of the past.
  3. crank
    crank
    Thanks for the guidence and info!!!!!!
  4. drdavewatford
    drdavewatford
    Sep 23, 2004
    42
    2910 sure does a good job via HDMI with my Pioneer 505XDE. Can't see why it wouldn't do the same with your plasma.
