Panasonic 42PHD8 or 42PV500
Discussion in 'Panasonic TVs Forum' started by djwoody, Sep 7, 2005.
  1. djwoody
    djwoody
    Sep 7, 2005
    116
    +3
    Due to the lack of stock of the 42PV500's and no-one really knowing when they'll arrive I've started looking elsewhere due to sheer frustration.
    The 42PHD8 looks like a good bet but obviously these (and any other non-tuner based plasma) are going to be hard to demo. It's hard enough to demo the 42PV500 in a proper environment !
    Does anyone have an opinion?
    I've had a 50" Panasonic plasma monitor (not TV) before a few years ago and the picture quality was spectacular and I havn'r seen anything since that rivals it.
    You don't actaully need a tuner based screen with Freeview / Sky etc.
    Look forward to your opinions.
  2. AndoverRed
    AndoverRed
    Sep 24, 2004
    252
    Andover
    +5
    The PHD8 gives you greater flexibility, you only need to buy the interfaces (component, HDMI, etc) that are required for your kit.
    By default an integral VGA and composite+s-video are available for immediate use. JS Tech produce converters if you wish to feed the VGA port with RGB (SCART) or component (DVD).
    The downside, compared with the PV500, is that speakers, stand, and tuner are additional items. This is not really a problem if you have an existing tuner/set-top box (freeview, SKY, ntl) and want to connect the audio directly to a surround sound receiver.
    I would, and most likely will, go for a PHD8. Save £600+ over the next 6 months and then buy a scaler. All your external devices can plug into the scaler and a single output (analogue or digital) can be fed into the PHD8 panel.
    Away with the mixer. :D
  3. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    A PHD8 will give a better picture with a scaler, but you are talking a lot more money, but more flexible.
    It depend what you want, if you want the ultimate picture and flexibility, then the PHD would suit you better.
    The PV500 is a wife friendly plasma that is very good at being a television.
  4. tscotsman
    tscotsman
    Dec 29, 2004
    849
    +16
    yeah im in the same situation, looks like my 42" wont arrive until the 20th at the earliest, im no the most patient at the best of times, but this time im truly anxious!!
  5. StrongSilent
    StrongSilent
    Jun 27, 2005
    498
    +6
    Anyone have prices, availability, lead times for the PHD8 ??
    Tavrymuch
  6. AndoverRed
    AndoverRed
    Sep 24, 2004
    252
    Andover
    +5
    Check out av-sales for pricing (£2,191.38 screen only). Limited stock due early September. Probably have to wait until October for volume stock.
    There should be a forum 'special' on the PHD8 in due course. I would budget £2,500 for panel+stand+component or HDMI module.
    This should match the PV500 with pedestal stand.
  7. davsdu
    davsdu
    Feb 13, 2005
    183
    +3
    Why is that? Wouldn't the PV500 produce the same quality if fed by the same scaler?
  8. foulkeg
    foulkeg
    What does the PHD8 have over the PV500?
    Whilst awaiting stock on the PV500 - I've looked into the PHD8 and found it to be only £80 less than the PV500.
    This means I've still got to find speakers/tuner/add-on inputs with my £80 change.
    Am I missing something in the specs?
  9. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    It's what the PHD lacks that improves it. Less on board processing, the modular inputs, much, much slimmer profile, native res on digital if you don't get bothered by frame rate conversion, or native at 50Hz on VGA. The lack of speakers, tuner, can be seen as an advantage. The fat bulge at the bottom (looks like a traditional middle aged west indian lady to me) and the STUPID place they've put the input ports leaves me speechless with rage! Not a screen for wall mounting, the PV500, it's far too much hassle. It takes about an hour, and all the skin off your knuckles to connect it, would you like me to continue?
  10. foulkeg
    foulkeg
    av-sales
    42PV500 £2,270.10 (Wall mount)
    42PHD8 £2,191.38
  11. ddlooping
    ddlooping
    Oct 7, 2003
    1,446
    Essex
    +27
    No need for a converter for component via VGA.
    You'd only need a component <-> VGA lead. ;)
  12. Sulis
    Sulis
    Mar 29, 2004
    577
    Bath
    But it looks great just sitting on the floor :).
  13. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Best left there, mate. Well, on it's stand anyway. Not a custom install product this one.
  14. pwood
    pwood
    Dec 6, 2003
    2,565
    Central Scotland
    +160
    I've got a PV500 and was considering the Panel version as well however patience ran out. I am impressed by the picture from freeview that this set produces and whilst I've got a decent surround set up the usefullness of a set of speakers is something that the wife likes and for casual viewing I use them as well. I've no intention of mounting on the wall so wasnt bothered about the wall mount bit and to be honest if i was going the wall mount route then the Pioneer with media box makes more sense as there is only 2 cables to the screen making future connections far less hassle plus its a darn sight lighter. For sure a scaler and panel would give the best PQ but I had to draw the line somewhere regards cost and useability.
    That all said mines being replaced as its whistles! Fortunately I purchased locally from a local dealer so customer care was something that I now am glad I factored into the purchase price.
  15. Sulis
    Sulis
    Mar 29, 2004
    577
    Bath
    Stand? Stays up perfectly well just as it is (that big bottom does have some use)...
  16. sapkan
    sapkan
    Jul 8, 2004
    496
    +4
    can the phd8 be ordered with matchind speakers?
  17. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,175
    Norwich
    +794
    Yes.
    you would obviously need to run a stereo feed from say the rec out of your av amp to the screen too if you hook up with component.
