Panasonic 37PW5 stand query
Discussion in 'Home Cinema Buying & Building' started by [email protected], Nov 12, 2004.
  1. bossc@
    [email protected]
    Dec 20, 2001
    1,163
    +273
    Can anyone advise what desktop stands the 37PW5 can use. Am I right in thinking that the 37 and 42 both used the same stand but the 50 was different. I've searched on here and have found a thread the 37" with this reference number : TY-ST42PT3-S which would indicate that its a 42" stand.
    Also, are the stands that can be used also able to be used across the different series 4th, 5th, 6th gen etc. If so, could anybody advise a good supplier/price for one of these. Thanks.
  2. njr
    njr
    Aug 23, 2002
    115
    16
    Berkshire
    A TY-ST05-K stand will do you.
    I have seen them on E-buyer, and I am sure AV sales will sort you out with one.
    Cheers, njr
  3. bossc@
    [email protected]
    Dec 20, 2001
    1,163
    +273
    Cheers for that. Searching on google shows a number of sites showing this as the stand for the 42" also which would indicate to me that the stands are designed to hold both sizes of panel as per my original post. I'm presuming that this applies to the other stands that are available also (the rounded ones - don't know the model number) that I personally find to be more attractive than this one with the feet.
  4. BruZZi
    BruZZi
    May 9, 2004
    28
    All Panasonic Stands will actually fit all three sizes 37", 42" & 50" .
    The TY-ST42PT3-K, TY-ST05K, TY-ST07K (Identical to the 05K), TY-ST10H & TY-ST42PA20 will fit your Display
  5. bossc@
    [email protected]
    Dec 20, 2001
    1,163
    +273
    Thanks bruZZi
  6. nathanf
    nathanf
    Mar 17, 2003
    52
    Hi, I know this topic is old, but I have just been given this display and I do not want to use the mount and have it on the wall. (I dont want it on show for all the local crooks to see!! :devil: )
    If I have it on the pedestal stand (TY-ST05) I can have it out of sight but i'm having problems finding that model.
    Does anyone know if I can use the Viera stands? TY-ST42PX20. I know someone said you can use the PE20.
    Ive found these at RS.
    http://ws4.richersounds.com/showproduct.php?cda=showproduct&pid=VISU-PLF420
    [​IMG]
    Will these work.
    Thanks in advance for any advice offered
    nathan
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  8. nathanf
    nathanf
    Mar 17, 2003
    52
    Thanks. I'm gonna try and buy one for from a shop first (I cant wait for delivery :devil: :D )
    I'm gonna go to Richer Sounds tomorrow and see what they have.
    :lease: I didnt get the screws that were supposed to be supplied. Can I buy there for anywhere like the ferrite core, or do I have to order them from Panasonic?
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    the screws are standard units but no idea on the size, unicol supply the right ones with the stands tho
