panasonic 37pv500b
Discussion in 'Panasonic TVs Forum' started by Andywilliams, May 4, 2005.
  1. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,091
    notts.
    +64
    Will almost certainly be getting this tv but the problem i have is where to put my centre speaker,At the moment it sits on top of my tv i havent any room underneath is there a speaker stand that i can put behind the plasma that will sit the centre speaker flush with the top of the screen or should i try and raise the plasma on its desk stand and put the centre just below in front of the screen. Centre speaker is 16' wide 7'high 8' deep.
    Cheers Gonzo. :)
