Panasonic 37PE50 and auto ratio switching
Discussion in 'Panasonic TVs Forum' started by nickg1977, Mar 10, 2006.
  1. nickg1977
    nickg1977
    Feb 28, 2006
    330
    Watford
    +22
    Hi all
    Bought this Plasma screen the other day thanks to some good advice on these forums. :thumbsup:
    I've managed to work out most of the "teething problems" myself but there is one that I need a bit of help with!
    I have Sky+ connected via RGB scart but I'm having trouble with the auto aspect ratio. I want it to be 16:9 when receiving an anamorphic signal, but 4:3 when not. If I set a 4:3 transmission to 4:3 it remembers the setting when I flick through the channels i.e. switches back and forth depending on the channel.
    However when I switch the set off it forgets this and just stays at 16:9 all the time until I repeat the above.
    Is there any way to set this permanently? I understand having to switch it manually for the component DVD connection, but didn't expect to have to do it for a scart one.
    Thanks for any advice
    Nick
