Panasonic 37PE30 vs 37PA30 ?
Discussion in 'Panasonic TVs Forum' started by therecanbeonly1, Sep 30, 2004.
  1. therecanbeonly1
    therecanbeonly1
    Dec 25, 2002
    92
    Gold Coast, Queensland
    I have seen the PA30 for under £1800 looks like a European model, are the only differances that the PE30 has a Freeview tuner? as I cannot receive Freeview and have Sky+ I am not worried about the tuner, are there any other differances or concerns I shoulds consider?
  2. Tonester
    Tonester
    Maybe you would find more problems getting it fixed under warranty as PA30 isn't officially sold in the UK?
  3. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
  4. therecanbeonly1
    therecanbeonly1
    Dec 25, 2002
    92
    Thanks for the info, found a good deal at BE-Direct, going to see if I can get it matched locally.
