Panasonic 37"
Discussion in 'Plasma TVs' started by archivedandy, Jul 28, 2003.
  1. archivedandy
    archivedandy
    Jul 28, 2003
    34
    Somewhere
    I am keen to buy a smaller than 42" screen for my new flat, of those I've seen the Panasonic 37" looks to be the best. (my best net price of £2499)
    Is it worth waiting for the 6-series? I'm not fussed about having a TV built-in as I use Freeview and run my PS2, DVD et al through a Scart switcher anyway. So I'd just use a JS Scart2RGB converter (thankyou forum users).
    If the new 37" has a TV built might it be a Freeview set? It seems bizarre to me that in these £x000 that all the manufacturers are doing is including bog standard TV!!
    Of course if anyone has anyother ideas for screens below 42" it'd be great to hear.
    A
  2. fancyabrew
    fancyabrew
    Dec 29, 2002
    332
    Plymouth
    +12
    I don't think there's going to be a 37" version of the 6 series 42" will be the smallest
  3. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    There will be a new 37", it will have a built in ANALOGUE tuner. That sounds a good price, and it's alovely little plasma, what make is your scart switch, there are issues with the lecktropaks one. Other than that, good setup.
  4. archivedandy
    archivedandy
    Jul 28, 2003
    34
    Somewhere
    Scart switcher is a Quintro+ which so far is proving a wonder!
  5. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    You should be ok with that, used one once, just make sure RGB is enabled on everything before you connect the plasma, it's a right pickle if not! No RGB = no picture =no setup menu.....
