Panasonic 37" series 4 offered. Should I get it?
Discussion in 'Panasonic TVs Forum' started by Bonzaimaster, Jan 10, 2003.
  1. Bonzaimaster
    Bonzaimaster
    Feb 8, 2002
    182
    16
    London
    I've been offered a brand new TH37PW4B from a retailer for £2295 (inc. VAT) with a one year guarentee. Apparently it does not come with any terminal board at the back (sounds odd to me) and I would need to purchase one myself as they don't sell them.
    I need some advice please.
    It's in their warehouse and they don't know if it's silver or black. Is it possible to tell from the model number?
    Can a RCA terminal board be purchased separately for the 37" Panny?
    If so, are they expensive?
    Is the series 5 terminal board compatible with the series 4?
    Is the series 5 table top stand compatible with the series 4?
    Many thanks
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,311
    Rainham Essex
    +2,425
    It's in their warehouse and they don't know if it's silver or black. Is it possible to tell from the model number? It is silver!
    Can a RCA terminal board be purchased separately for the 37" Panny? Yes, but it should come with the plasma. Mine was inside the plasma box but had to be plugged into the unit.
    If so, are they expensive? Yes. For the price they are asking you should get a plasma including the board.
    Is the series 5 terminal board compatible with the series 4? NO!
    Is the series 5 table top stand compatible with the series 4? YES!
    Mark.
  3. Bonzaimaster
    Bonzaimaster
    Feb 8, 2002
    182
    16
    London
    Any recommendations for suppliers of a series 4 RCA terminal board please?
    The Panasonic centers I have called seem to think that it's not possible to source one anymore.
  4. jmack
    jmack
    try giving nexnix a ring there at the top of this website
  5. Bonzaimaster
    Bonzaimaster
    Feb 8, 2002
    182
    16
    London
    Just had a thought.
    Does anyone who replaced their RCA terminal board with a BNC or tuner version want to sell their old board?
