Panasonic 37 plasma
Discussion in 'Panasonic TVs Forum' started by flashy-nashy, Dec 24, 2004.
  1. flashy-nashy
    flashy-nashy
    Could anybody please tell me the wiring configuration, ie what goes where with what sort of cable. I have a panasonic th37pe plasma, sky + with optical link and a pioneer home cinema. My theory is that the home cinema will work with any dvd that I choose to play or via any sky channel. Please help.
    regards
    Flashy -Nashy
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    is it TH-37PE30B? And what pioneer HC??? Basically you need to connect both with RGB SCART to Plasma (component if HC has it and you should be able to use HC for Sky sound as well as TV sound, but need far more info first...
    AS for cables all you need is available here: www.tvcables.co.uk
