S
Si-Tec
Just received one of the above and can't seem to get rid of digital picture artifacts produced by the 100Hz processing. The severity depends on the source material, but there is always something present no matter what. I've tried RGB and component inputs from DVD player and digi-box, 100Hz plus, 75Hz, progressive, and combinations of comb filter and noise reduction, but to little avail. Most pictures also have a slight halo effect, and no really clean edges either- I'm also putting this down to the 100Hz system.
Otherwise, the set has excellent colour, contrast, geometry and the potential for loads of clean detail...
So the simple question is, does the PD50 have an un-molested 50Hz interlaced mode? I'm sure it would cure all this sets ailments!!
Many thanks
Si
Many thanks
Si
