Panasonic 32ps12
Discussion in 'TVs' started by 1_crazy_mofo, Aug 15, 2004.
Tags:
  1. 1_crazy_mofo
    1_crazy_mofo
    Hi can anybody help ? i purchased a set in april 2004 and have a intermittent fault the set just seems to go into stand by mode the supplying dealer said it cant happen /never heard of it etc etc i am at the end of my teather it seams to switch to av when it feels like it ????? please help
  2. dempsey
    dempsey
    Can't help with the cause of the fault but if you can't solve it yourself and the selling dealer is unable to help you would need to take it to a local panasonic approved service dealership. Panasonic website should tell you your nearest one if you dont know it.
