Panasonic 32PL10 - query
Discussion in 'General TV Discussions Forum' started by baseborn, Aug 9, 2002.
Tags:
  1. baseborn
    baseborn
    Basically - am thinking of getting this TV....
    But - is it possible to switch between 100Hz and 50Hz modes???
    - cos i've heard for some things, 50 is better than 100..
    OR
    Am I better getting the PL1......??
    Oh yeah...does the PL10 have 3 scarts or two like its little Brother!!
    Cheers...
    Baseborn
  2. Dunkwho
    Dunkwho
    Sep 3, 2001
    531
    28
    Dunstable
    +24
    2 scarts, no way of switching to 50hz that i've found.
  3. Corbin
    Corbin
    I've got the 28" model.
    Apparently in the set up menu, if you switch off flicker reduction, it's supposedly reverts to 50hz. I must say that I do notice a big difference between the two settings especially when viewing any sort of text on screen. Flicker reduction certainly stops the text from jittering.
  4. Corbin
    Corbin
    Oh, and it only has two scart sockets. Ext 1 RGB enabled.
