Panasonic 32PD50 & Sony VTX-D800
Discussion in 'TVs' started by per-Sony-fied, Sep 26, 2005.
Tags:
  1. per-Sony-fied
    per-Sony-fied
    Jul 24, 2005
    2,277
    +100
    Does anybody own this combination?
    I have a problem that exsists via S-video and RGB that gives the result of white horizontal flickering lines on a black background and appear black on a red or blue background (normally has to fill most of the screen). A white background seems Ok (I think) since a box reset.
    Other units via these sources seem ok (Humax PVR, Sony DVD, Arcam DVD).
    I've tried 2 Sony VTX-D800 freeview boxes so it isn't a box fault per say and has never been noticed via the Sony TV it used to be attached to.
    I've contacted Sony and Panasonic to no avail. Sony only saying the tuner is sensitive and any aerial misalignment could *perhaps* cause this and Panasonic saying that the box may have a o/p to high for the set. Huh? surely there's some room for movement in the threshold specs.
  2. per-Sony-fied
    per-Sony-fied
    Jul 24, 2005
    2,277
    +100
    What no one? :( Not a single soul with anything like this problem?
  3. per-Sony-fied
    per-Sony-fied
    Jul 24, 2005
    2,277
    +100
    Crumbs... remain surprised. So anyone with a Freeview box attached?
