Panasonic 32pd50 and Sky
Discussion in 'General TV Discussions Forum' started by john read, Mar 19, 2005.
Tags:
  1. john read
    john read
    Just purchases Panasonic 32PD50 and must say I am a bit disapointed!
    The picture is great with DVDs but i spend most of my time watching SKY+ live or off-air recordings. Ths picture from Sky looks quite pixilated and blurry compared to my old 28" JVC.
    I am using a standard scart from the SKy box into the TV and the picture settings that work best are "Normal" and "Progressive".
    Can anyone giveme any further help on how to inprove the picture.
    cheers
    JR
  2. Trickdick
    Trickdick
    Feb 6, 2005
    69
    I've had a new 32 PD50 for a few days and am delighted with the picture from Sky+
    Are you using a decent Scart cable or a cheap one?
    What are your picture settings - if you let me know I'll check them against mine.
    Hope this helps
  3. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    Its not the tv, its the source from sky.These sets shows the sky picture for what it is- :thumbsdow
  4. iaTa
    iaTa
    Mar 11, 2005
    237
    +14
    See my post about quality from Sky+ to my PD50 :)
  5. john read
    john read
    Thanks guys
    Ben- wheres your post?
    Trickdick- I use the "Normal" and "progressive" settings for the picture. Is there a way i can give you numerical numners for hte settings (i.e. for brightness, contrast etc.)?
    cheers again
    jr
  6. john read
    john read
    I really am p**sed off. :mad:
    Just spent £30 on a Thor scart to see no discernable difference in picture quality. If anything it really highlights the poor picture from SKy.
    Is there any point in having a 32" screen if your main picture source is Sky???
  7. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    Have heard a few people quoting that freeview is less noisy on 100htz tvs.
  8. iaTa
    iaTa
    Mar 11, 2005
    237
    +14
    Try the component input mate - trust me you wont regret it :)
  9. MikeD
    MikeD
    Mar 17, 2001
    265
    Paignton, Devon, UK
    Strange, I've just bought a brand new 32" PD30 and SKY from an aging Panasonic digibox is superb!
    In fact the same can be said about my DVD player and hard drive recorder on the PD30, I've only used 0.75m Vivanco leads costing £13 each.
    Frankly I,ve never seen TV as good as this and I'm a long time Sony fan and owner.
    Good luck and hope you get it sorted, MikeD
  10. billystevo
    billystevo
    Mar 13, 2005
    53
    9
    Your best picture will be on Channel 5 then 4 if you get a bad picture on these channels, i suggest you ask for an engineers opinion you might have a lemon. :eek:
