I don't think 100hz is the MAIN difference, the main difference is they are 2 completely different panels as I mentioned earlier. I think you can consider the LMD and LXD different in the way you could consider the differences between Toshiba's C and X ranges different. Quite simply, I believe you get what you pay for in this regard as the budget panels always tend to show off more of the disadvantages of LCDs.
