Panasonic 32LXD70 Power On/Off Problem?
Discussion in 'Panasonic TVs Forum' started by AnthonyG, Sep 21, 2007.
  1. AnthonyG
    AnthonyG
    Nov 23, 2005
    8,855
    +1,188
    I have a question about the Panasonic 32LXD70. This has been my very first LCD and I love it immensely. I had bought it on its first fortnight of release in April 2007 from John Lewis.
    However there is one slightly odd thing about it which I have persevered with assuming it is just a standard design feature about all LCD's.
    But to power on the LCD from standby I need to hold the red power button on my remote control for about 2-3 seconds. And then to turn it off I need to do the same. Pressing the Power button on the remote less than this needed 3 seconds does nothing but give a slight few flashes on the TV's power button but doesn't turn it on or off.
    I just stuck with this as it is something that you would assume is a design feature for possibly preventing the TV from being switching on or off if you sit on the remote or something.
    However I have just yesterday bought a Logitech Harmony 555 remote control and this 'feature' of the Panasonic TV is throwing a major spanner in the works as the Harmony will only give a short 1 second burst of Power on/Power off that is not held long enough (i.e the 2-3 seconds) to actually turn on or off the TV.
    And as the way the logitech works, i.e via set control macro's for whatever you ultimately want to achieve, e.g watch a DVD, Play a Game. I can't use the controller I have just paid £70 for.
    Any Ideas on what to do with this problem, and if this is actually a standard thing with the 32LXD70.
    Anthony
  2. blue max
    blue max
    Apr 12, 2006
    12,946
    London
    +4,315
    Well it's not a fault, it's the same on my previous model panny. I have much the same problem. There might be some reason for the 'soft start', but I can't bring it to mind at the moment.
    Graham
  3. deadmonkey
    deadmonkey
    Aug 16, 2005
    485
    28
    +35
  4. Mostly_Harmless
    Mostly_Harmless
    May 14, 2006
    2
    I have a 32LMD70 and was having the same problem. Yesterday when I tried fiddling with the settings in the Harmony software I got a message saying there was an update available for the TV device. I accepted the update, which created another TV, and altered the activities to use the "new" TV - which was all done automatically. The TV now switches on OK using the Harmony remote. :thumbsup:
