Panasonic 32LXD60 - xbox 360 and dvd dilemma - only 1 component input on tv
Discussion in 'Panasonic TVs Forum' started by mrpaddlepop, Mar 25, 2006.
  1. mrpaddlepop
    mrpaddlepop
    Just got one of these tvs for my room, and i dont know which to connect via the component.
    At the moment the xbox uses the component socket.
    My dvd player only has component output so just wanted to know whether it is good to get a "component into scart" lead.
    can anyone help or advise on a decent component to scart cable or their suggestions on this setup?
    ive found some on ebay for £10 - £50 :lease: help me
    thanks
  2. dllord
    dllord
    Sep 8, 2005
    1,054
    48
    +30
    Just get a component switch box!
  3. mrpaddlepop
    mrpaddlepop
    ive never heard of it???
    will that keep the quality???
    any chance of recommending a brand or model number so i can see it on ebay
    thanks
    :rolleyes:
  4. stevelup
    stevelup
    Aug 13, 2002
    6,795
    Swindon
    +1,298
    Anything will probably do - just make sure you don't buy one where the output cable is permanently attached - they are invariably crap.
    It's also possible to use a standard cheap AV switch - one that has L+R audio / Composite Video (Red / White / Yellow phonos). You should be able to pick something up from Maplins or CPC for less than a tenner - add your own decent quality component leads and you will be fine.
    Steve
  5. mrpaddlepop
    mrpaddlepop
    cool!!!
    as long as the quality remains im a happy bunny!!!! :D
    phew, i was about to pay oer £60 for the composite - scart cable (QED), can go out and buy another games!!!! :thumbsup:
  6. scrapbook
    scrapbook
    Jan 12, 2002
    7,448
    +555
