Panasonic 3000:1 conrast ratio
Discussion in 'General TV Discussions Forum' started by Sam Carter, May 24, 2002.
Tags:
  1. Sam Carter
    Sam Carter
    I noticed that the Panasonic has a contrast ratio so much higher than most plasmas which are 700:1
    How come this is so? And does this mean Panasonic gives the brightest picture?
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,940
    The Borders
    +3,332
    Hello Sam
    No it means it has the best contrast ratio - on paper!
    The Pioneer panels tend to have the edge on brightness and the Panasonic panels have the edge on detail levels in the dark areas of the image.
    The higher brightness/contrast ratios also tend to hint at being able to run your panel far longer before any noticeable image degradation sets in (25K hours+) as you will probably never run the panels at full brightness anyway.
    Joe
  3. Sam Carter
    Sam Carter
    So can I safely say a 700:1 contrast ratio is good enough?
