PANASONIC 28" WIDESCREEN TV.
Discussion in 'General TV Discussions Forum' started by The Foot, Aug 29, 2005.
Tags:
  1. The Foot
    The Foot
    Dec 17, 2004
    272
    16
    I have had my Panny for a while now but have just bought a Toshiba RDXS34 recorder (which is a pig to work out!!). Anyway my question is...when I turn my TV on it always defaults to a terrestrial channel and I then have to use a macro on my remote to get it to switch to SKY. Is this a standard thing with Pannys or is there a way I can get it to go straight to SKY?
  2. norm
    norm
    Feb 2, 2005
    349
    Devon
    +7
    On mine TX28-PM12 it switches to AV when something on SCART switches on.
    One annoying aspect though is the grey logo that remains on screen in the top left corner telling you the mode and channel, which has to be switched off via the remote.
  3. The Foot
    The Foot
    Dec 17, 2004
    272
    16
    Not sure what you mean by something on scart switches on? R u saying when you switch TV on it goes straight to SKY or do you have to select something first?
  4. norm
    norm
    Feb 2, 2005
    349
    Devon
    +7
    Switch on television, shows normal TV, then switch on say Sky box it should switch to that.
  5. JayCee
    JayCee
    Jan 20, 2004
    22,194
    Lanarkshire
    +2,310
    If scart switching has been enabled in the "Services", "Picture Settings" menu of the Sky digibox.
