Panasonic 28" widescreen.. strange dots!
Discussion in 'General TV Discussions Forum' started by mmj, Jun 9, 2004.
Tags:
  1. mmj
    mmj
    Aug 9, 2003
    56
    Hi everyone,
    I bought a Panasonic 28" widescreen television a while back as it was said to have very impressive picture quality, it is the TX28PS12 (i think).
    Anyway, I have noticed that flicker is quite bad when watching DVD's at the static menus, so I go into the options and enable Flicker reduction and the picture is steady as a rock, but I've noticed that with flicker reduction enabled there are like strange dots that occasionally appear around text, they are very annoying can I fix this?
    Thanks.
