panasinic e50 questions
Discussion in 'Blu-ray & DVD Players & Recorders' started by chic, Oct 16, 2003.
  1. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    i hav recently bought a panasonic e50 and it records of sky to the sony dvdr medium and plays back on the panasonic fine, but it will not play on any other dvd player i have. My question is it possible to record something on the panasonic and play it back on another player, if so what media is the best ot use and do i have to set something up on the recorder to enable this.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,700
    Warwick
    +2,578
    I read your post as "you have made a recording off Sky on a Sony DVD-R but it won't play back on your normal DVD player" - is that correct? If so the reason for this is you need to Finalise the disk.
    Insert the DVD-R, goto Functions/Disk Information and select Finalise. This will turn the DVD-R into a DVD-Video that will play in virtually all DVD players.
    If you use DVD-RAM disks you will get numerous features but the disks will not play back in most DVD players.
  3. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    yep i did not finalise the disc ,so i will try when i get home tonight thanks for the help
  4. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    managed to get it to work now thanks to Rasczak:smashin:
