Panaqsonic PV500 design?
Discussion in 'Plasma TVs' started by ErikX, May 24, 2005.
  1. ErikX
    ErikX
    Sep 14, 2004
    84
    I am one of many that hated the design on the Panny PA30. The design alone prevented me from investing in that screen. What I particulary hated was the broad silver "thingy" at the bottom of the screen. Ugly!
    Is the Pv500 design exactly the same as the PA30? (I hope not)
    Regards,
    Erik
  2. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,077
    notts.
    +63
    Have a look at the screen on www.Avland.co.uk they have a very good picture of the screen,It looks to me very nice and is different to the pe30 design.
    Cheers Gonzo.
    Ps you can also check the pe30 on site for the comparison.
  3. smultron
    smultron
    Mar 6, 2003
    60
    Hamburg, Germany
  4. neilmcl
    neilmcl
    Oct 29, 2004
    6,216
    103
    Nottingham
    +290
  5. ErikX
    ErikX
    Sep 14, 2004
    84
    To me it looks like the PV500 design is identical to the PA50 design. Correct?
  6. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,077
    notts.
    +63
    No Erik
    The pv500 is a design of its own.The pe50 has the speakers underneath the screen the pv500 has speakers built in to the screen frame(at the sides) the pv500 is slimmer at the bottom of the screen (than pe30)with hardly any curve.
    Hope this helps.
  7. ErikX
    ErikX
    Sep 14, 2004
    84
    Thanx gonzo. That was exactly what I wanted to hear. Can't wait until they get it here in Norway so I can check it out myself!
