Panansonic PW6 - Soft Pcture when playing DVD
Discussion in 'Plasma TVs Forum' started by Micklewhite, Jan 9, 2005.
  1. Micklewhite
    Micklewhite
    Nov 6, 2004
    7
    Hope someone here can help me, or give me some pointers.
    I recently purchassed a PW6 and have connected my Sony DVD Player (DVP-CX860) upto the screen via component, with a custom made higrade component lead.
    However the picture is looking very soft, almost as if I was watching a video. I have a media centre PC connect via the VGA port, and using the TV tuner on this, the picture looks good.
    Do you think it's a case of playing with the settings on the Display (is there an advanced option, i'm not seeing for settings?) or is it the Component lead I have?
    Any thoughts would be appreciated, as I'm rather dissapointed with the picture quality at present.
    Many Thanks
    M
  2. tij303
    tij303
    Dec 25, 2003
    102
    Ive just set up my PW6 to a pioneer dvd player. At first my pioneers settings were set to rgb and not component output - have you checked the actual DVD plaer's settings? I assume you have also set the pw6 up for component as well. Finally double check by using a scart lead into the rgb slot - if it is better then it might be your leads ? I run my component through an amp and the picture is the same as a direct feed, very sharp and clear. Hope this helps you.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    is DVD progressive scan? if so trun it off...... Run interlaced component to screen (are we talking PAL or NTSC material here?
  4. Micklewhite
    Micklewhite
    Nov 6, 2004
    7
    There's no prog scan on my player (about 4 years old). The problem seems to appear with both PAL and NTSC.
    I have adjusted the contrast and colour levels tonight, after reading another post. It does appear to have improved, but still not anywhere as sharp as I would expect :(
