Panamorph lens for MT1z?
Discussion in 'Projectors, Screens & Video Processors' started by Paul D, Dec 30, 2000.
  1. Paul D
    Paul D
    Dec 27, 2000
    2,794
    Manchester
    +557
    Maybe a silly question but although i see plenty of people talking about this lens for other projectors, nobody talks about one for the toshiba MT1z. Even if nobody makes one for mine, how much are these lenses, also who sells them?. ( I've got a feeling the MT1z plus the forth coming MT2z will be very big in the budget home cinema market). ANY replies on this subject would be gratefully received. , Thanks Paul.....
    I'am not drinking anymore....but i'am not drinking any less
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    F: The panamorph is a seperate lens I think that sits in its own enclosure in front of your chosen projector. Don't think that there'd be any problem suing it with your unit.
    It would allow you to use the full resolution of your 4:3 lcd panel to play back anamorphic discs as the lens would squeeze the image vertically.
    You would have a problem using it to watch 4:3 material and letterbox stuff though unless your Toshiba has user definable aspoect ratio's. The solution would be to remove it when watching these.
    I don't think there is a UK distributor, although I may be wrong.
    Gordon
    StereoStereo
    Intelligent Solutions for Intelligent Homes !
  3. gotalifethanks
    gotalifethanks
    Anyone seen the lens you can buy for the Sony VPl-10ht beastie??
    I know they are $600 dollars or so but are they any good???
    Ta
