Pana PW6 Speakers
Discussion in 'Home Cinema Speakers' started by Redrob, Sep 16, 2004.
  1. Redrob
    Redrob
    I have just bought the Pana PW6 & need to organise the sound side of things, budget has stretched as far as it will go for the time being and I am considering buying the side mount speakers which I can pick up for around £200. Is there a reasonable alternative in this price range or do I go with these until my budget allows me to upgrade?
    Redrob
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    If you don't have a seperate amp, then I would buy the PW6 speakers and use those. I doubt the internal amp in the plasma would have the power to drive seperate speakers and would probably damage them if you tried.
    Alternatively get a £100 stereo amp (or even a cheap DD Receiver can be found for this money) and a pair of small bookshelf speakers, which would be my choice. You can buy the other 3 speakers when you have more money in the future.
  3. Alan_W
    Alan_W
    Sep 20, 2000
    1,393
    S Wales
    +188
    I have just wired up an old small set of speakers to the Panny speaker output for watching "normal" tv. Sound is more than acceptable, and very convenient for a quick watch, without having to fire up the "system" :thumbsup:
  4. Redrob
    Redrob
    Thanks for the replies guys, looks like the pana's then. At least until I'm ready to invest in something serious :devil:
    Redrob
