Pana Pw6 Setup Help Needed
Discussion in 'Plasma TVs Forum' started by BridoF, Nov 3, 2004.
  1. BridoF
    BridoF
    There seems to be many setup questions posted but everyone being slightly different. Being a complete novice I am seeking advice on the best setup for me.
    I have a PW6 with Scart board. This is due to be wall mounted in a garage conversion so need to get the cabling right in order to hide it!!
    Here's what I will be connecting together:
    PW6
    DVD Player (Connections available are Scart, S-Video, Video Out, Analog Audio Out, Digital Audio Out (Optical and Coax))
    Sky Digi-Box
    PS2
    Just about to buy a Denon Amp
    Is it best to feed everything to the amp and then connect this to the PW6? If so how? Should I try and exchange the Scart board for a Component one or should I connect to the VGA slot?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  3. BridoF
    BridoF
    Thanks. I have had a look at this thread. Still unclear for a real novice like me!!
    Should I connect all to the amp and then from that to the Scart on the PW6?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    which denon amp? Ideally connect it all to amp then amp to screen via component if amp is 3805/4 or 2805 it will upconvert S-video to componet ideally DVD player should ouput componet and get componet cable for PS2 then sort out sky.................PS where did you buy all this and not get advice on how to connect it?
