Quantcast
pana e55 prob help needed
SILVERBACK
i have my sky+ hooked up to the pana e55 and everything was fine untill i left the dvd recorder on an switched off the sky+,it makes a horrendous noise through my speakers on my amp and it looks like the pic is still on the screen but looks like it has been streamed badly even though the sky+ is off,can some one check there e55 and make sure its just my dvd recorder please:( thanks in advance.i only have it hooked up using scarts btw.
ps everything goes back to being fine as soon as the sky+ is switched back on.
SILVERBACK
problem solved it was the bloody splitter i have it hooked upto:rolleyes: :censored: :rotfl:
