Pana DMR-EH50 - Pure NTSC recordings
Discussion in 'Blu-ray & DVD Players & Recorders' started by MikeNolan, Sep 9, 2005.
  1. MikeNolan
    MikeNolan
    Nov 28, 2004
    540
    Hereford
    Can this machine record from pure NTSC signal? If yes, will the disc be able to be played in any other DVD player/recorder? Thanks
  2. the.jackall
    the.jackall
    Mar 3, 2003
    29
    Northumberland
    it sure does,just switch the tv setting in the connections menu to NTSC and fire away,once you have finalized it just plays back the same on any machine.
  3. Bal2005
    Bal2005
    Apr 25, 2005
    170
    UK
    +3
    Onething you may need to remeber is that your TV may display your output in B&W but this normally happens if your TV does not fully support pure NTSC. Most have a converter and just converts in a susdo signal I think they call it.
    I have a E85 and my NTSC recordings or Pal ones have a symbol on the thumbnail.
