Hi, I have just purchased a panasonic th 42 pwd6, and am very pleased with it. I have it running thro a daewoo plasma tuner model DSA 9310 E, connected via the VGA socket. I have a progressive scan dvd player, and would like to know the best set up solution for this. In addition, as I am a newbie to the plasma scene, does the daewoo tuner give rgb signals to the plasma from the vga socket in, or do i need to go scart. Any help is greatly appreciated. Thank you.
take the Daewoo tuner box back to RS it is useless and buy a component to VGA cable for the DVD to connect to the VGA on the plasma..... then either buy a scart board and a Freeview box/sky/cable cox or a DVD recorder for TV veiwing read this thread: http://www.avforums.com/forums/showthread.php?t=154292
