Pan & Scan problem with Pioneer DV-444
Discussion in 'Blu-ray & DVD Players & Recorders' started by al_the_man, Sep 11, 2004.
  1. al_the_man
    al_the_man
    Hello,
    Am new to these forums and am looking for a bit of help regarding the pan/scan feature on my Pioneer DV-444 player. It is hooked up to a 21" Toshiba TV via a SCART cable (not all 21 pins appear to be present on this, but it was bought as such and works).
    When I select the 4:3 pan & scan option, the picture is increased in size height wise (the black bands are reduced in size) but the sides of the picture are not chopped, meaning the aspect ratio becomes distorted.
    What am I doing wrong??
    Thanks in advance,
    Alan
    (apologies if this has been posted in the wrong area!)
  2. Simon6776
    Simon6776
    Jan 7, 2003
    2,258
    West Sussex, U.K.
    +33
    Not sure if it's the solution, but I would certainly get a fully wired, 21 pin scart lead, as my main priority.
    Just a thought, but have you tried with both Fullscreen and Widescreen DVDs?
  3. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,623
    2
    In a secret location with Jennifer Lawrence
    +9,336
    Welcome to the forums al_the_man.
    We have dedicated forums for each type of question. Yours is more suited to the DVD players forum. Moving there, you should get more response.
    Greg
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,390
    Somewhere in South Yorkshire
    +5,778
    If you are talking about the 4:3 pan & scan option in the player's setup menu, then this feature will only work properly on anamorphic widescreen DVDs which have a pan & scan code signal mastered on them.......and very few do. What it should do in the absence of such a code signal, is generate a letterboxed image.
    However, that doesn't fully explain the shape of picture you are describing.
