fly-catchers
I finally had my Pan EX85 repaired for its know faulty Freeview tuner. It had also been getting numerous U80 errors before the tuner packed up. Thanks to this forum I was able to direct the repairers in the correct direction!
Today I got the unit returned. They had replaced the back-end pcb and 680uf cap. And updated the software to the latest version. So far so good!
But on switching it on it now keeps displaying a U61 error on the unit and on the TV screen saids it must affectively reboot. So you either press "enter" or just leave it and after a while it saids "bye" and switches off. After a while it switches back on with "hello" and briefly seems ok before the error message comes up again. It just keeps doing this. Will it eventually settle down and work or is it toast again? Currently I have switched it off at the mains and will give it an hour or so before trying again.
It was repaired under an extended guarentee but the setup to that is most annoying as I am in SE Kent and the repairers D&G use are in Blackpool! So all you see are a courier company picking up and delivering the machine and no engineer to talk to!
According to the Panasonic instructions the U61 is not a fault and it restores the unit to normal operating mode. But it just keeps recycling this message!
cheers
bill
cheers
bill
