Pan E55 vs Sony RDRGX300
Discussion in 'Blu-ray & DVD Players & Recorders' started by daylightfading, Dec 8, 2004.
  1. daylightfading
    daylightfading
    Folks
    I am pulling my hair out trying to decide between both machines. The Sony is slightly dearer and both machines get fab reviews but any users out there with their own opinions?
  2. Mark Spanner
    Mark Spanner
    Dec 11, 2002
    264
    Norfolk, UK
    +5
    Just got the E55 - love it too bits.
    The sony obviously is more compatable with formats but i'm lovin the RAM!
    Also managed to get it cheap - £199 from boots + £24 worth of Boots points so essentially paid £176. Very happy!
  3. Rasczak
    Rasczak
    Apr 3, 2002
    21,221
    Argyll
    +2,268
    The Panasonic E55 is significantly better than the Sony. 3hrs full resolution recording, DVD-Audio and Flexible Record set it above the latter. The Sony is a good DVD recorder - and ideal if you need compatible re-writeable media - but to use all the features of it you need to use DVD-RW VR mode in which case you might as well use DVD-RAM which has somewhat slicker editting/playlists.
  4. daylightfading
    daylightfading
    Thanks guys for your help.
