Palm Tungsten E2 GPS System
Discussion in 'Mobile Phones Forum' started by hinz, Aug 12, 2005.
  1. hinz
    hinz
    Aug 12, 2005
    10
    I'm looking for a good GPS system for the Palm Tungsten E2 which i'm getting for free.
    Now i've found the Kirrio ViaMichelin GPS Navigation Pack V3 Bluetooth for Palm & Pocket PC
    Does anyone on this forum have this? Any good or bad points about it?
    Are there any better GPS systems out there for the E2, or cheaper ones that do just as good job?
    Any help is greatly appreciated
  2. lurcher
    lurcher
    May 15, 2003
    4,216
    Stalybridge
    +221
    Dont know if its of any help but I"ve got the Palm T3 and got the Tom Tom 3 wired system for it , works very well. Bluetooth version available.
  3. hinz
    hinz
    Aug 12, 2005
    10
    You got a link for both versions?
  4. DennyL
    DennyL
    Aug 1, 2004
    114
    There's a Mapsonic forum at Pocketgps.co.uk, with plenty of reported user experiences of the various versions of Mapsonic. There's also a Palm forum there.
  5. hinz
    hinz
    Aug 12, 2005
    10
    Thanks, will check it out.
  6. RohanM
    RohanM
    Jun 4, 2004
    362
    London
    +32
    The following forum is good and pretty thorough:
    http://pocketgpsworld.com
    lots of info, so be prepared for a full data download on the pros/cons of the various software available!!! They also have their own speed camera database...
  7. hinz
    hinz
    Aug 12, 2005
    10
    Decided I'm gonna go for the Tom Tom 5 Navigator. Seems like the best option :)
    Also i'm going to get the Acer n30 which is a much better PDA since it's on Windows Mobile platform.
    thanks for the help
    hinz
