PAL60 Query
Discussion in 'Blu-ray & DVD Players & Recorders' started by ScottW75, Sep 7, 2004.
  1. ScottW75
    ScottW75
    Feb 5, 2003
    4,497
    +843
    I've just bought a pw6 plasma and i'm very pleased with it. However my HK 2550 outputs pal and NTSC blacks at different levels. Its been suggested i use pal60 to get around this rather than turn the brightness up and down. i'm using the component input and have a few questions
    1.will using pal60 increase the pitch of the audio or will it remain the same?
    2.will it negatively affect the picture in anyway (3:2 pulldown etc?)
    thanks for any help
  2. SilverPenguin7
    SilverPenguin7
    Mar 4, 2002
    443
    +21
    I have the exact same equipment and problem as you. I posted about it a while back if you do a search. Int he end I found out there is no way around it unless you either adjust the brightness each time or do what I did and use pal60 for everything. I did checks to see if there were any negative effects to running R1 at pal60 and to my eyes there seemed to be no difference. Just dont forget to set the player to progressive everytime you turn it on in the eZmenu (its the far right hand side figure and it needs to be set to 2).
    Hope that helps or puts your mind to rest :)
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,572
    Somewhere in South Yorkshire
    +6,093
    1: No. PAL 60 uses the same frame and line structure as NTSC; only the colour carrier is changed. No effect on speed, resolution, etc.
    2: See 1.
