PAL Xbox - hi-def without chipping?
Discussion in 'Xbox Forums' started by leedavies, Aug 15, 2004.
  1. leedavies
    leedavies
    Jul 8, 2004
    192
    Cambridge
    +7
    Is there any way I can get hi-def output enabled on my PAL Xbox without chipping?
    I use Xbox Live most of the time and want hi-def output whilst online.
    Once my console is sorted, will PAL games give me hi-def?
    Thanks.
  2. inzaman
    inzaman
    Dec 16, 2002
    7,964
    Derby
    +1,029
    With the MS high def kit i am pretty sure you will get 480p which is still far better than the standard connectors. I you do a search i think that there has been a lot of discussions on this in the past few months.
  3. leedavies
    leedavies
    Jul 8, 2004
    192
    Cambridge
    +7
    Yes, have seen discussions on the MS hi-def kit.
    Am looking for the definitive answer on whether I can combine PAL Xbox, hi-def output and Xbox Live without needing to flip a switch and make sure I don't log onto Live with it flipped the wrong way...
  4. inzaman
    inzaman
    Dec 16, 2002
    7,964
    Derby
    +1,029
    You can combine a non chipped xbox and ms high def kit, you will need to chip your xbox though if you want to use enigma which enables 720p and 1080i. I cannot see any reason, although havent tried it, why a high def kit with non chipped xbox would lock you out of live.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Gamester Component kit gives you 480p not sure if it all games or just some.
  6. Monster
    Monster
    Oct 9, 2000
    978
    Adelaide
    +30
    Is there a significant difference between using RGB scart and the component kit using a standard PAL X box?
    I display using a Panny PTAE300 via RGB scart at the moment.
    I don't want to bugger up Live by modding my console (and frankly find it a bit confusing what to do but will look at X Box scene!)
    But want the best picture I can.
    Why on earth can't we have HD quality pictures just cos were in Blighty??? Hopefully this will not be the case with X Box 2!
  7. Pooon
    Pooon
    Dec 26, 2002
    7,354
    Canterbury, Kent
    +944
    I have used two different types of component cables on my standard PAL xbox which is connected to my 32" Toshiba, and the results have been disapointing to say the least. The image was much much darker on both cables compared to the Official M$ Advanced Scart which i have now switched back to. The two brands of component cable that i have used have been the Gamester pack that get mentioned alot and this one WhiteDog and i wouldn't recommend either.
  8. zedzed
    zedzed
    Jul 12, 2004
    821
    Linlithgow (nr. Edinburgh)
    +13
    Monster - I've read there's a way to to make your xbox output in NTSC video mode (and hence enabling HD) without modding. It involves using a "save game" hack/method - although I've not got much further in my investigations! I found a post at http://ntsc-uk.domino.org/archive/index.php/t-24801.html - but haven't got much further! Let me know if you do :)
    ZedZed
