pal Xbox AV cables?
Discussion in 'Xbox Forums' started by bongpig, Dec 13, 2003.
  1. bongpig
    bongpig
    Hi all,
    I have a pal xbox, and need to pull from it a component Y-U-V sinal for my TV, and an optical digital signal for surround sound.
    Ive found optical digital cables for sound, but the vision side of the cabel is only a 21 pin scart.
    And, on the other hand, ive found a component cable, but that only has normal stereo left/right signals.
    I want half of one and half the other!
    Are there any cables ( for pal xbox ) that have seperate component signals for the visual side of things, and and optical digital cable for the audio?
    thanks
  2. cheesyhammyeggy
    cheesyhammyeggy
    If you do a search you will find loads about this, you cannot get a compnent cable in the uk that has an optical connection but you can get them overseas and they will work with pal xbox. A search will reveal the threads with links to the correct leads.
  3. gpa
    gpa
    Hmmmmmmmmmm
    well i must have been very lucky then because i went to my local games shop and thats exactly what they got me, give it a try.
  4. bongpig
    bongpig
    well at least i now know such a cabel exists! Thanks guys.
    Ill dig around and see what I can find.
    gpa, does this cable you got hold of have a specific name?
    cheers
  5. gpa
    gpa
    Hi Yes Its seems to be the standard xbox hi-def pack lead part no X08/25301
    hope this helps
  6. Synchronicity
    Synchronicity
    Mar 6, 2003
    2,816
    +214
    hmmmm,Im confused now:rolleyes:
    Ok,I think I made a mistake in buying this cable:
    http://www.consoleplus.co.uk/product_info.php?cPath=34_49&products_id=252
    Obviously now I realise that the sound is gonna be prety crap cos its only got the standard phono leads for audio...
    but this 1:
    http://www.whitedog.co.uk/catalog/product_info.php?cPath=9_47&products_id=82
    ..has the optical audio cable but only standard svideo or rgb scart for video:confused:
    So do I gain sound quality with the second 1 but lose picture quality?:suicide:
  7. Synchronicity
    Synchronicity
    Mar 6, 2003
    2,816
    +214
    bump:confused:
  8. bongpig
    bongpig
    Jason, it seems only the Xbox high definition pack ( or the gamestar equivilent ) have both component video as well as optical digital sound.
    Ive discovered the TV im getting has component inputs labeled : Y,Pb,Pr
    Can anybody shed some light on this type of component input? Would the high definition pack work in this example?
    Im suddenly worried that it wont work.
    ( I know I wont get Progressive scan due to my xbox being PAL, but i would still like the component video )
  9. Synchronicity
    Synchronicity
    Mar 6, 2003
    2,816
    +214
    The cableavailable from whitedog is apparently component and has the optical but it doesnt have those Y,Pb,Pr connections,just s video,rgb scart,etc,Im just confused as to wether these will provide the same pq.
  10. Kramer
    Kramer
  11. bongpig
    bongpig
    Thanks Kramer, but being the dumb ass i am, Im still a little confused.
    I guess what im simply asking is, does the xbox output Y,Pb,Pr component through the HD AV packs.
    Im not concerned about Progressive scan.
  12. Kramer
    Kramer
    Y, Pb, Pr is progressive component.
    Y, Cb, Cr is interlaced component.
    A "standard" Pal xbox will out put 525i (or 480i?) via its Y, Cb, Cr (component outputs) but you'll need a US/Japanese or modified xbox for progressive scan & higher resolutions (games permitting).
    Component is different from RGB & slightly better IMO, even in interlaced form.
    For £23 delivered, if you've got a component capable display you can't really go wrong with the hi def kit.
    :smoke:
  13. bongpig
    bongpig
    Thanks Kramer. Thats cleared it up. So my xbox will work with my ( soon to have ) plasma with YPbPr inputs ( also labled YCbCr ) using the high-def pack. Yippee!!
    Now .... whats the deal with the gamecube? ( yes i have one of them too! )
    Can I assume the same applies when using the cube component cable?
  14. Synchronicity
    Synchronicity
    Mar 6, 2003
    2,816
    +214
    Where can I get this cable from and does it have the optical output for sound?Sorry if Im being thick and have missed the link,work is melting my brain:zonked:
  15. Kramer
    Kramer
