PAL TV in France
Discussion in 'General TV Discussions Forum' started by [email protected]@y, Sep 3, 2004.
  1. BigB@dJ@y
    [email protected]@y
    Nov 23, 2002
    258
    Lancashire
    My Dads moving to France soon and he would like to know if his Pal TV will work over there (they use Secam IIRC)?
    BBJ
  2. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,760
    71
    Land of the Living, Essex
    +47
    Does his tv accept NTSC signals? should work fine if does mate.
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,554
    Somewhere in South Yorkshire
    +6,057
    What? Where's the connection between NTSC and SECAM?
  4. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,760
    71
    +47
    there isnt one, its just a safe bet that if your TV accepts NTSC signals its more than likely it'll accept seecam (which is very similar to PAL anyway)
  5. BigB@dJ@y
    [email protected]@y
    Nov 23, 2002
    258
    Lancashire
    Dont know if it accepts NTSC but I dont think that makes any difference tbh.
    Its an oldish (about 7 - 8 years old) widescreen (Will have to check the model number)
    As said above they use SECAM in France (if he has to buy a new one Im nicking his old one when he goes :D)
  6. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,760
    71
    +47
    if you say it like that then is TV wont work in france :devil: :)
    most PAL TV's should be fine with seecam, it will tell you in the manual anyway
  7. mrtbag
    mrtbag
    Dec 17, 2002
    3,657
    Anywhere I want
    +394
    Genrally PAL TV's will not work in France. Most modern PAL TV sets have a PAL tuner, and will accept an NTSC signal via Scart. On larger high spec sets this may also include SECAM input via Scart. But at a guess, I would say only 10% of large screen sets in the UK are capable of this. If he's mocing for a long time, and wants to receive the French TV channels, I's sell his set before he leaves and buy a new one out their. Most SECAM sets sold in france have a PAL input via SCART, so he can keep his DVD Player.
  8. BigB@dJ@y
    [email protected]@y
    Nov 23, 2002
    258
    Lancashire
    Thanks Mrtbag...Thats just what I needed to know :D
    The old telly will be mine :D
    Cheers :rotfl:
