PAL Standards supported by new Sony's
Discussion in 'General TV Discussions Forum' started by RAC, Apr 10, 2001.
  1. RAC
    RAC
    Time to change the telly.... getting stuff on-line seems much harder over here in Belgium than in the UK, BUT, British TV is broadcast in PAL-I whereas they use PAL-G here in Belgium (and PAL-H in the Netherlands and Germany). Does anyone have a new Sony TV (I'm interested in the KV-32FX65 model) and does the manual say anything about the PAL standards it supports.
    My moan - this is just the sort of information that would lend itself to being buried on a website. Why can't manufacturers just post an Acrobat copy of all their manuals on the web - it would make life so much easier!?! Cheers. :rolleyes:
  2. RAC
    RAC
    I really would be grateful if any of you Sony owners could dip into the manual for me. Thanks v.m. :)
  3. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,202
    Born in Bristol but now in Newport, (for my sins)
    +739
    I have the 36FS70 and that supports ALL the PAL standards.
    It says in the book that it supports PAL(I) and a few others (G & H I am sure)...
    Even if it doens't, out of the box, the service menu allows you to select the PAL mode, and also the country of origin!!
    Infact, i can even tell my TV that its a different model, which makes me think that this is the case for ALL Sony TVs.
    I hope this helps
    Jon
