iamthehighway
I lugged my Aussie PAL ps3 all the way to Japan and for the last year have been using a computer monitor using HDMI to display it.
Last week i decided to buy a proper tv, Sharp 32 inch Aquos, only to find the dreaded "unsupported signal" prompt from the tv when using HDMI. then found out japanese tvs dont support PAL at all.. even brand new sets like this.
ive seen other posts on this and the solution seems to be to use composite Green, Blue and etc cables, the problem here is this set doesnt have em...to get to the menus ive used RCA cables which, due to PAL/NTSC differences, is in B+W...
the other options for connecting are S-Video and DVI... would DVI connection be useful here does anyone think?
just wanted to check before i cry more, accept defeat and buy a japanese PS3...
