PAL ProScan on Arcam any closer?
Discussion in 'Projectors, Screens & Video Processors' started by Xevian, Oct 13, 2001.
Tags:
  1. Xevian
    Xevian
    Oct 3, 2001
    62
    9
    Farnborough, Hants, UK
    So is a legal PAL ProScan standard any closer?, looking in perticular at the Arcam FMJDV27?
    Any idea's when?
  2. Guest
    I spoke to Arcam about this earlier in the week.. unusually, the guy i spoke to was a bit dismisive of the whole subject.. didnt get an answer out of him im afraid.
    I have been told that their is a secret menu on the DV88 where you can enable it.. anyone know if you can do the same on the DV27?
    Cheers,
    Kev
  3. Guest
    thought id better point out that i mean the DV88 with a Prog Scan upgrade board..... before people jump down my throat ;o)
  4. lmccauley
    lmccauley
    Oct 24, 2000
    3,534
    Newcastle
    +327
  5. Jenz
    Jenz
    Yes you can on the DV27 ;)
  6. Xevian
    Xevian
    Oct 3, 2001
    62
    9
    Cheers for that, looks like I will get a DV27 then ;)
    Where's the best/cheapest place to get one?
  7. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Best place to get one: An Arcam FMJ dealer. (Like me)
    Best price £1,600, you won't find it any cheaper.
    You can get it in black now also if required.
  8. Halcion
    Halcion
    Oct 11, 2001
    78
    9
    If you *really* can do Pal Prog on the Arcam FMJ-27, then PLEASE divulge the secrets.
    I can't even make it region free with the supposed remote trick.
    I'm therefor just about to take this player back, because if I can't active regionfree/pal prog, then it's utterly useless to me as anything but a cd player.
    Cheers,
    halcyon
    PS [email protected] dot com. Connect the dots. I didn't write it literally correct in order to avoid spambots.
  9. simoncope
    simoncope
    Have you spoken to your dealer? They should be able to point you in the right direction. If not, be more persuasive!!
