pal projector calibration
Discussion in 'Home Cinema Buying & Building' started by Peter Maciw, May 20, 2003.
  1. Peter Maciw
    Peter Maciw
    How do people calibrate their projectors?
    I have seen the Avia disk but this is only for NTSC. Is there anything that can be used on a region 2 DVD with PAL output.
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,152
    UK.
    +2,671
    You can use the THX optimax found on some THX disks, but these tend to be just for the disk they're on, and often you'll find the drop shadow test doesn't have a drop shadow...
    What DVD player do you have? If it has a 0ire setting for ntsc (or a black level setting), then using the needle pulse tests from Avia should be OK as the black level for both PAL and NTSC should be the same then IIRC.
    I'm also wondering that if you use PAL60 for NTSC sources, then the black level could be the same for both - anyone know if this is the case?
    Cheers.
    Gary.
  3. Mr.D
    Mr.D
    Jul 14, 2000
    11,165
    +1,202
    You'll find the THX optimode on a few 625/50 region2 discs.
    However Avia and or Video Essentials is really the prefered method.
    There are reasons why the PAL/NTSC issue is a bit of a misnomer with dvd but there has been lots written on here about the issues.
    In practice its unlikely you'll have problems using a 525/60 disc for calibration with few exceptions.
  4. Mr.D
    Mr.D
    Jul 14, 2000
    11,165
    +1,202
    Black set-up is 0IRE for PAL , RGB and component.
    Only NTSC is 7.5IRE
  5. dunkyboy
    dunkyboy
    Jun 5, 2002
    635
    London
    +6
    Apparently Video Essentials is getting a sequel very soon. Called Digital Video Essentials, it's initially being released on D-VHS D-Theatre format in high def resolution for $90, but it'll be released later on ordinary DVD, in both PAL and NTSC, for $30 IIRC.
    Cheers,
    Dunc
  6. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,152
    UK.
    +2,671
  7. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Digital Video Essentials is released on PAL and NTSC DVD versions on July 15th. You can pre-order for $25 each from www.widescreenreview.com/index5.html Hope this helps.
    Steve
