PAL Progressive yet?
Discussion in 'Blu-ray & DVD Players & Recorders' started by RedRose, Oct 9, 2004.
  1. RedRose
    RedRose
    Jan 30, 2002
    110
    Preston, Lancs
    Hi, it's been a while. I think it's time to replace my Sony 355 player (which has been absolutely superb) which cost me £355 for something which will play all these new fancy MP3s, DVD -R+R+RW-RW etc. for about £150 tops. (God my head spins at the very thought). I'm even thinking about a DVD recorder but the format wars are VERY confusing.
    Question: Is Progresive scan now commonly available for PAL. I ask because it only used to be available for NeverTwiceSameColo(u)r and dodgy shops would claim Progressive Scan but only for Region 0 NTSC discs. Has anything changed? Thanks.
  2. lmccauley
    lmccauley
    Oct 24, 2000
    3,434
    Newcastle
    +272
    Yes, Arcam produced the first completely legit PAL PS player, and PAL PS is now fairly common-place.
    Cheers,
    Liam
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    £150 will get you either a panny DMR-E55 recorder see special offers forum...... or the excellent Pioneer 575 DVD player......
    Both PAL PS so really depends if you want recorder or more accomplished player...
  4. nwgarratt
    nwgarratt
    May 5, 2002
    27,150
    +3,022
    I can recommend the Sony NS585 player. I have had one for a couple of weeks for use with a projector. It has both NTSC and PAL PS, plays mp3's and every type of DVD.
    I got a multiregion version from Amazon.co.uk for £99.99. The R2 only version is £88.
  5. RedRose
    RedRose
    Jan 30, 2002
    110
    Preston, Lancs
    Thaks for the feedback and the PM. The Sony 930 does look impressive but I feel myself gravitating towards a DVD recorder. So I guess I should switch forums but I wanted to say thanks. BTW - Most sources I've found on the Web seem to imply that the Panny E55 is only Progressive on NTSC (sounds like old times) . Can anyone categorically refute this e.g. have you seen a Plasma display a "625P input" from it?
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
