PAL progressive scan
Discussion in 'Blu-ray & DVD Players & Recorders' started by Kain, Jul 13, 2002.
  1. Kain
    Kain
    Jun 11, 2002
    265
    16
    Dubai, UAE
    +3
    In order to "display" PAL progressive scan on a TV, does the TV have to support PAL progressive scan or will PAL progressive scan work on any progressive scan cabable TV?
  2. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    It needs to support Pal Progressive. Unfortunately, no current UK TV's do support this with the exception of a Loewe with Q2500 chassis and VGA board installed. Even then, the signal must be fed through a transcoder (unless your DVD player supports PAL Prog and has VGA out) as the input method is VGA. Apparantly, the picture reproduced is as close to perfect as you can get but the VGA display on the Loewe does not allow for correct aspect ratio display. This means you need to manually adjust the H & V Size controls to suit. Also, it is impossible to get certain aspect ratio's to display correctly as these controls are limited. If you do a search on Loewe Pal Progressive you should bring up a few interesting threads.
    It has been rumoured that the new Toshiba ZD26 Tv's accept Pal Progressive (they definately do NTSC) but I haven't been keeping up with that thread. Do a search for more information.
  3. Kain
    Kain
    Jun 11, 2002
    265
    16
    Dubai, UAE
    +3
    Thanks.
    But if the DVD player can output a PAL progressive scan signal, then any progressive scan capable TV will display as PAL progressive?
  4. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    No, the TV must be able to sync to to PAL Progressive. If the TV is NTSC Progressive only then it will not display the Pal Progressive source.
  5. Kain
    Kain
    Jun 11, 2002
    265
    16
    Dubai, UAE
    +3
    Ah, okay.
    Thanks. :)
  6. jmack
    jmack
    does this apply to plasma tvis as i have the philips 42pf9964 and was thinking about ordering the philips Q50 progressive scan dvd from hivizone in the usa
  7. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    As far as I know most Plasma Screens can accept a 720p Pal Progressive signal but I'm not really up on Plasma's so don't quote me on that :).
  8. Kirk
    Kirk
    Jul 2, 2002
    309
    Somewhere on t'internet
    Hmmmm I am interested in the answer to this one as I have to admit I was blindling believing that by getting a Toshiba 42WP16 Plasma and a Denon DVD-2800 MKII would give me PAL & NTSC Prog. Scan!!
    I was gonna use the component outputs from the DVD direct to the component inputs on the Tosh (which is a Panny by any other name)
  9. jont
    jont
    Apr 8, 2002
    4,288
    near Aylesbury
    +556
    Yes the panny/tosh can display an ntsc and a pal prog on the component inputs ... if that helps ...
  10. Gordon @ Convergent AV
    Jul 13, 2000
    14,214
    +3,058
    720P is not pal progressive. It's 576P....
    Not all plasma's will sync to such a signal so you need to check with Philips. To echo JohnT. Yes the Toshiba will.
    Gordon
  11. Kirk
    Kirk
    Jul 2, 2002
    309
    Excellent! Thats a relief :D
    Now just gotta wait for the DVD-2800 MKII to become available! :p
